[Armbian build PR] - Bump igorjs/gh-actions-clean-workflow from 2 to 3
Bumps igorjs/gh-actions-clean-workflow from 2 to 3.
Release notes
Sourced from igorjs/gh-actions-clean-workflow's releases.
v3
What's Changed
Full Changelog: https://github.com/igorjs/gh-actions-clean-workflow/compare/v2...v3
Commits
  • e5de22f Merge pull request #42 from igorjs/fix/22-implement-pagination-scan-when-resu...
  • 4f3d6bb chore(ci): update dist folder
  • 226d7c8 fix: implements pagination over 100 workflow runs
  • 8c87a3f feat: paginate api results
  • 8260e41 Merge pull request #41 from igorjs/chore/update-readme
  • a37bbf0 chore(docs): update readme
  • See full diff in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
