RSS Bot Posted July 13, 2022 Posted July 13, 2022 If the Raspberry Pi Pico’s 2MB of QSPI flash is not quite sufficient for your needs, and you’d not quite a fan of micro USB ports, the WeAct RP2040 clone comes with up to 16MB flash and a USB Type-C port for power and programming. Another improvement is the addition of a reset button, which can be convenient for flashing UF2 firmware, and the pinout remains the mostly the same. The price is not quite as low as the original Raspberry Pi Pico, but the clone sells for an affordable $5.99 with 2MB flash, while the 16MB flash variant goes for $8.99 with shipping included in both cases. WeAct RP2040 specifications: MCU – Raspberry Pi RP2040 dual-core Cortex-M0+ microcontroller @ 133 MHz (overclockable to 250+ MHz) with 264KB SRAM Storage – 2MB to 16MB QSPI flash USB – 1x USB 1.1 Type-C port used for power and programming Expansion 2x [...] The post WeAct RP2040 board adds 16MB flash, USB-C port to Raspberry Pi Pico form factor appeared first on CNX Software - Embedded Systems News. View the full article
