[CNX-Software] - 5V wireless LED lights up thanks to magnetic resonance coupling technology
Wireless power 5V LED
Wireless power, no matter how inefficient it may be, sounds good and even looks good with the “5V remote wireless power supply LED pack” we feature in this post. It also feels magical with the LEDs lighting up thanks to magnetic resonance coupling technology. The solution comes with a coil as a transmitter and each LED bead also includes a small coil as a receiver. When the two are coupled, energy can be transferred from the transmitter to the receiver through the air, paper, or plastic casing, and the LEDs will light up. The magnetic field intensity in this technology is said to be similar to that of the Earth’s magnetic field, and it will not be harmful to human health and other devices. Specifications: Transmitter Module Input Voltage – 5 V Power – 0.5W (10 LEDs) Transmitting Coil Outer Diameter – 70mm, inner diameter 65mm, thickness 0.5mm Transmitter Board [...]
The post 5V wireless LED lights up thanks to magnetic resonance coupling technology appeared first on CNX Software - Embedded Systems News.
View the full article
