[CNX-Software] - 7.9-inch ultrawide HDMI display works with Raspberry Pi SBC
7.9-inch ultra-wide display
If you are looking for an ultrawide display to show information on your PC or Raspberry Pi, there’s a 7.9-inch IPS display with 1280×400 resolution that may meet your requirements. The display is powered through a USB port and outputs video through an HDMI 1.4 input port, so it should work with any hardware equipped with HDMI input and a USB port. LR79 display specifications: Display – 7.9-inch TFT-LCD IPS display with 1280×400 resolution @ 60Hz, no touch function 178° field of view 5:16 aspect ratio Response Time: 40ms(Typ.)(Tr+Tf) Contrast Ratio: 900:1 Brightness: 500cd/㎡ Color Gamut: 70% NTSC Display Colors: 16.7M Backlight: WLED (19.2V) Connector: 30-pin ZIF Display Input – HDMI 1.4 Power Supply – 5V via micro USB port Dimensions 205.8 x 67.6 x 13.3 mm Active Area – 190.08 x 59.40 mm Weight – 108 grams The display should work with any host with HDMI output, but it’s [...]
The post 7.9-inch ultrawide HDMI display works with Raspberry Pi SBC appeared first on CNX Software - Embedded Systems News.
View the full article
