[CNX-Software] - Pinecil V2 soldering iron gets BL706 Bluetooth LE RISC-V MCU, USB PD EPR support
Pinecil V2 RISC-V soldering iron
PINE64 is about to launch the second generation Pinecil RISC-V soldering iron with the Pinecil V2 featuring a new Bouffalo Lab BL706 RISC-V microcontroller with Bluetooth LE connectivity, optimizations for higher power levels, as well as tentative support for the new USB PD EPR standard (Extended Power Range) working at up to 28V. I don’t solder every day, but when I do, I use my Pinecil soldering iron, as it’s heating super fast and does the job, and in my case, works quite better than the TS100 soldering iron. So it should come as no surprise that the Pincel is the most popular consumer hardware from the PINE64 community (after SOPine modules), and the new Pinecil V2 is a welcome upgrading building on the same design but with Bluetooth LE connectivity and a lower tip resistance.   Pinecil V2 preliminary specifications: MCU – Bouffalo Labs BL706 32-bit RISC-V microcontroller @ [...]
The post Pinecil V2 soldering iron gets BL706 Bluetooth LE RISC-V MCU, USB PD EPR support appeared first on CNX Software - Embedded Systems News.
View the full article
