RSS Bot Posted August 10, 2022 Posted August 10, 2022 Renesas RZ/N2L is an Arm Cortex-R52 microprocessor (MPU) family for industrial Ethernet communication equipped with an integrated TSN-compliant 3-port Gigabit Ethernet switch and an EtherCAT slave controller. The new processors also support other major industrial network communication protocols such as EtherCAT, PROFINET RT, EtherNet/IP, and OPC UA, as well as the new PROFINET IRT (Isochronous real-time) that allows deterministic communication with cycle times down to 31.25 µs and one µs of jitter. Renesas RZ/N2L key features and specifications: CPU – Arm Cortex-R52 @ up to 400MHz with 16KB I-cache with ECC, 16KB D-cache with ECC Memory Tightly coupled memory – 256KB with ECC Internal RAM – 1.5MB with ECC Octa/Quad SPI for HyperRAM, HyperFLASH, SRAM, SDRAM Networking Ethernet L2 switch: 3x external ports with Gigabit support TSN support (IEEE 802.1AS-2020, IEEE 802.1Qbv/802.3br, IEEE 802.1Qbu, etc.) Network redundancy support (DLR, PRP) EtherCAT slave controller Industrial Ethernet – EtherCAT, PROFINET RT/IRT, EtherNet/IP, [...] The post Renesas RZ/N2L Arm Cortex-R52 MPU targets industrial Ethernet and TSN appeared first on CNX Software - Embedded Systems News. View the full article
