[CNX-Software] - $4.9 CAN bus module features GD32E103 Cortex-M4 microcontroller
CAN Bus Grove module GD32E103
Seeed Studio has introduced a new CAN Bus Grove module based on 120 MHz Gigadevice GD32E103 Arm Cortex-M4+ microcontroller with support for CAN FD at up to 5Mbps and controlled by AT command over a serial interface. The new module appears to be a drop-in replacement for the company’s $19.90 Serial CAN-BUS Grove module based on Microchip MCP2551 and MCP2515, and the main benefit of the new GD32E103 module is that it is much more cost-effective going for only $4.90 including shipping. GD32E103 CAN BUS Grove module specifications: MCU – Gigadevice GD32E103 Arm Cortex-M4F microcontroller @ up to 120 MHz with 64KB to 128KB flash, 20KB to 32KB SRAM CAN Bus – 2-pin terminal block with CAN FD up to 5 Mbps Host connection – 4-pin Grove connector with UART up to 115,200 bps (default 9,600 bps) Misc – Tx and Rx LEDs Operating voltage – 3.3V Dimensions – 40 [...]
The post $4.9 CAN bus module features GD32E103 Cortex-M4 microcontroller appeared first on CNX Software - Embedded Systems News.
View the full article
