RSS Bot Posted August 20, 2022 Posted August 20, 2022 A couple of months ago, we wrote about the Raspberry Pi Compute Module 3E (CM3E) equipped with the Raspberry Pi RP3A0 SiP found in the Raspberry Pi Zero 2 W board. It looks like an OEM product from Raspberry Pi trading, and as such is close to impossible to purchase. But if somehow, you’d like to have the guts of the Pi Zero 2 W into CM3 module form factor, Waveshare has designed the Zero-to-CM3 adapter for the Raspberry Pi Zero 2 W that should be compatible with most carrier boards designed for Raspberry Pi CM3 or CM3+. As you can see, it is also using pogo pins to connect to the test points on the Raspberry Pi Zero 2 W board in order to route the USB, USB OTG, and SD card signals, so it will not work on older Pi Zero boards since the test points are in [...] The post Raspberry Pi Zero 2 W board gets Raspberry Pi CM3 adapter appeared first on CNX Software - Embedded Systems News. View the full article
