RSS Bot Posted August 22, 2022 Posted August 22, 2022 Mirek Folejewski has designed the ridiculously tiny Femto module based on the Raspberry Pi RP2040 microcontroller with a size of just 12x12mm, and still including an SPI flash, a crystal, and a few passive components. We’ve previously covered some really tiny RP2040 boards with the Pimoroni Tiny 2040 and Adafruit QT Py RP2040 boards, as well as the RP2040 Stamp module, but the 12x12mm Femto module is about a quarter of the size of 25x25mm RP2040 Stamp. Femto specifications: MCU – Raspberry Pi RP2040 dual-core Cortex-M0+ microcontroller @ up to 133Mhz with 264kB of SRAM Storage – 4 to 64Mbit QSPI flash I/O – 30 GPIO pins, Reset and BOOTSEL signals, etc… exposed through a frame (See below) Misc – Status LED, 12MHz crystal oscillator, decoupling capacitors Dimensions – 12 x 12mm The board is comprised of two parts: the module itself (aka mainboard) with the Raspberry Pi RP2040 microcontroller [...] The post Femto is a tiny 12x12mm Raspberry Pi RP2040 module appeared first on CNX Software - Embedded Systems News. View the full article
