[Armbian build PR] - rockchip64: edge kernel, remove inno usb2 phy init code causing kernel fault
Description
A change in kernel 5.19.2 causes kernel oops in inno usb2 phy initialization (at least) when there is an usb3 type-c connector device (like fairchild usb3 controller) trying to initialize the usb2 phy.
My Orange PI 4 LTS was entering kernel panic when the monitor was brought on by effect of fusb302 kernel module initializing the whole type-c subsystem (display port, usb2 and usb3 phys).
This patch removes the init code introduced in 5.19.2
How Has This Been Tested?
  • [x] Produced kernel debs and installed on living Orange PI 4 LTS system
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
