I have set
kernel.panic=180
in /etc/sysctl.conf to reboot on a kernel panic.
Before, the system would keep running/hanging and I could read the errors if I turned on a attached display.  Now the result is that the tinkerboard switches off.  My expected result would be a reboot.
Do I have to set something else?  Or do I need to use watchdog
I am using the original tinkerboard with debian bullseye, kernel 5.15.48-rockchip.
Edited by tinker
vor 1 Stunde schrieb jock:
If you run echo b > /proc/sysrq-trigger from root does the board reboot or turns off?
It reboots instantly.
(If it matters, I installed the watchdog package in the meantime, but did not configure it yet, I can uninstall it, if it matters for testing)
