I have a new odroid XU4 that I plan to use for Home Assistant in Docker and run other services in containers.  I have loaded a fresh copy of Armbian cli (fully updated) with bluetooth from armbian-config. I installed linux drivers for my usb module (rtl8761a) from the manufacturer and it comes up in "bluetoothctl" as registered and pairable. However "bluetoothd show" gives me  a "D-Bus setup failed: Name already in use." I will need dbus to pass device information between my docker containers when I install docker and home assistant so this error is concerning. Any ideas on how I might resolve this error?
Thank you
armianmonitor url: http://ix.io/48FG
Edited by rostar99
clarity
