RSS Bot Posted August 31, 2022 Posted August 31, 2022 EasySensors “6Gang30AmpsLatchRelayEspHomeReady” (now that’s a product name!) is a DIN Rail mountable, ESP32-S2-based automation device featuring six 32A latch relays and supporting ESPHome open-source framework. The system also comes with two inputs for Dallas temperature sensors, two buttons for manual control of relays, a USB-C port for programming, as well as an external SMA antenna for WiFi connectivity. 6Gang30AmpsLatchRelayEspHomeReady specifications: Wireless SoC – Espressif ESP32-S2 Xtensa single-core 32-bit LX7 microcontroller @ up to 240 MHz with 320 kB SRAM, 2.4 GHz WiFi 4 (Matter-ready) Antenna – Embedded IPX to SMA adapter, 3dBi antenna I/Os 6x 32A latch relays with zero current idle consumption 2x Dallas temperature sensor pins with 5 kOhm pull-up resistors USB – 1x USB Type-C for programming via CP2102 USB to TTL chip Misc 6x control buttons, Reset button 6x status LED’s, 2x status LED’s Input Voltage – 85 to 305V AC Dimensions Board – 147 x [...] The post ESPHome compatible ESP32-S2 module offers six 32A latch relays in a DIN Rail enclosure appeared first on CNX Software - Embedded Systems News. View the full article
