[CNX-Software] - USB4 Version 2.0 to enable speeds of up to 80 Gbps, introduce “active” USB cables
USB4 Version 2 80Gbps
The USB Promoter Group has just pushed a press release about the “pending release” of the USB4 Version 2.0 specification that promises up to 80 Gbps of data performance over the USB Type-C cable and connector. The group also explains both the USB Type-C and USB Power Delivery (USB PD) specifications will also be updated, and everything will be published right before the USB DevDays developer events planned for November 2022 in the US and South Korea. So that’s basically an announcement about a future announcement, but we were still provided with some highlights of the upcoming USB4 v2 specification: Up to 80 Gbps operation based on a new physical layer architecture, using existing 40 Gbps USB Type-C passive cables and newly-defined 80 Gbps USB Type-C active cables. Updates to data and display protocols to better use the increase in available bandwidth. USB data architecture updates now enable USB 3.2 [...]
The post USB4 Version 2.0 to enable speeds of up to 80 Gbps, introduce “active” USB cables appeared first on CNX Software - Embedded Systems News.
View the full article
