[Armbian build PR] - Fix armbian header
Description
A couple of regressions from #4013 and #3619 was fixed. The first one causes Ambian Sid images to hang until Ctrl+C is pressed at login. The second regression is minor, and
Finally, the logic is updated to detect Debian Sid and Bookwork using lsb_release when available.
How Has This Been Tested?
This was tested on Armbian Sid on a La Frite, by modifying the /etc/update-motd.d/10-armbian-header script before logging in again.
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
