[Armbian build PR] - Bump ossf/scorecard-action from 1.1.2 to 2.0.3
Bumps ossf/scorecard-action from 1.1.2 to 2.0.3.
Release notes
Sourced from ossf/scorecard-action's releases.
v2.0.3
Patch for fix in #898
v2.0.2
Fixes ossf/scorecard-action#895
v2.0.1
Fix for #856
v2.0.0
What's Changed
... (truncated)
Commits
  • 865b409 Create v2.0.3 patch (#927)
  • 60f6d77 :seedling: Bump github.com/google/go-cmp from 0.5.8 to 0.5.9 (#855)
  • a73c72a bug: always use the default GITHUB_TOKEN for signing (#898)
  • 68bf5b3 🐛 Fixes Run all checks on a BranchProtection event - failing tests (#897)
  • f437b3c Downgrade to scorecard:v4.5.0 to fix breakage (#894)
  • 13ec8c7 :seedling: Release v2.0.0 (#854)
  • 183420b :seedling: Included License (#852)
  • 9347866 :seedling: Bump github/codeql-action from 2.1.21 to 2.1.22 (#853)
  • d4f9a7a Add docs for API (#849)
  • 9b15950 :seedling: Bump actions/cache from 3.0.7 to 3.0.8 (#836)
  • Additional commits viewable in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
