[CNX-Software] - ChipWhisperer-Husky is a palm-sized power analysis and fault injection tool (Crowdfunding)
power analysis fault injection tool STM32F Target Board
NewAE Technology’s ChipWhisperer-Husky is a compact tool designed for side-channel power analysis and fault injection with features such as a high-speed logic analyzer used to visualize glitches, real-time data streaming for attacking asymmetric algorithms, and support for JTAG/SWD programming. The security research company explains its device delivers a more stable and reliable experience compared to other off-the-shelf test gear such as oscilloscopes and function generators thanks to features such as synchronous sampling, which means the sample clock of your target device and the sample clock of ChipWhisperer-Husky can be perfectly aligned, or the ability to generate glitches, including clock glitches that can be less than a  nanosecond wide.   ChipWhisperer-Husky key features and hardware specifications: Synchronous clock for capture board and target board for significantly improved performance over a typical asynchronous oscilloscope setup 12-bit 200MS/s ADC for capturing power traces – It can be clocked at both the same clock [...]
The post ChipWhisperer-Husky is a palm-sized power analysis and fault injection tool (Crowdfunding) appeared first on CNX Software - Embedded Systems News.
View the full article
