[CNX-Software] - OnLogic IGN800 Industrial Raspberry Pi Edge Gateway runs Ignition Edge software
OnLogic IGN800 Ignition Edge Software
OnLogic IGN800 is an industrial edge gateway based on the Raspberry Pi CM4 module pre-loaded with the Ignition Edge HMI, SCADA (Supervisory Control And Data Acquisition), MES, and IIoT software platform from Inductive Automation. The hardware is not exactly new, as the Onlogic IGN800 is simply the OnLogic Factor 201 industrial PC introduced earlier this year, but that ships with Ignition Edge in order to provide a cost-effective solution for automation projects. OnLogic IGN800 specifications: SoM – Raspberry Pi CM4 with Broadcom BCM2711 quad-core Arm Cortex-A72 processor @ up to 1.5 GHz, up to 8GB LPDDR4 RAM, up to 32GB eMMC flash Additional storage – Optional M.2 SATA SSD (See Expansion section) Video Output – HDMI port up to 4Kp60 Networking 2x Gigabit Ethernet LAN (Optional PoE PD Input) via Realtek RTL8153 controller Optional WiFi/Bluetooth module on Raspberry Pi CM4 module + 3x antenna holes Optional 4G LTE wireless module [...]
The post OnLogic IGN800 Industrial Raspberry Pi Edge Gateway runs Ignition Edge software appeared first on CNX Software - Embedded Systems News.
View the full article
