[CNX-Software] - ESP32 DevKitC V4 IoT development board ships with ESP-WROOM-DA dual antenna module
ESP-WROOM-DA development board
The ESP32 DevKitC V4 is now selling with the ESP-WROOM-DA module with two PCB antennas that was introduced last year in order to offer a longer WiFi range and better reliability. The development kit is exactly the same as for the other ESP32 DevKitC V4 module, and the only difference is the dual antenna design. When running a recent version of the Arduino Core for the ESP32 (2.0.3 or greater), the ESP32 will automatically switch to the antenna with the strongest signal in order to deliver the best connectivity possible. ESP32 DevKitC V4 specifications: Wireless module – ESP-WROOM-DA (PDF datasheet) with SoC – Espressif Systems ESP32-D0WD-V3 dual-core LX6 microprocessor with 520 KB SRAM, 2.4 GHz WiFi 4 and Bluetooth 4.1 connectivity Storage – 4MB SPI flash Two PCB antennas (ANT1 and ANT2) USB – 1x Micro USB port for power, programming, and debugging through USB-to-UART bridge up to 3 Mbps [...]
The post ESP32 DevKitC V4 IoT development board ships with ESP-WROOM-DA dual antenna module appeared first on CNX Software - Embedded Systems News.
View the full article
