RSS Bot Posted October 3, 2022 Posted October 3, 2022 Bumps ossf/scorecard-action from 2.0.3 to 2.0.4. Release notes Sourced from ossf/scorecard-action's releases. v2.0.4 Fixes #856 What's Changed :seedling: Bump github.com/caarlos0/env/v6 from 6.10.0 to 6.10.1 by @dependabot in ossf/scorecard-action#934 feat: do not run signing on pull requests by @laurentsimon in ossf/scorecard-action#935 :seedling: Bump debian from 11.4-slim to 11.5-slim by @dependabot in ossf/scorecard-action#936 :seedling: Bump github.com/sigstore/cosign from 1.11.1 to 1.12.0 by @dependabot in ossf/scorecard-action#938 :seedling: Bump github/codeql-action from 2.1.22 to 2.1.24 by @dependabot in ossf/scorecard-action#941 🐛 Restore behavior of ignoring scorecard runtime errors by @spencerschrock in ossf/scorecard-action#948 :seedling: Bump actions/dependency-review-action from 2.1.0 to 2.4.0 by @dependabot in ossf/scorecard-action#950 :seedling: Bump github.com/sigstore/cosign from 1.12.0 to 1.12.1 by @dependabot in ossf/scorecard-action#947 :seedling: Bump github/codeql-action from 2.1.24 to 2.1.25 by @dependabot in ossf/scorecard-action#949 :seedling: Bump codecov/codecov-action from 3.1.0 to 3.1.1 by @dependabot in ossf/scorecard-action#942 Create v2.0.4 patch by @spencerschrock in ossf/scorecard-action#952 New Contributors @spencerschrock made their first contribution in ossf/scorecard-action#948 Full Changelog: https://github.com/ossf/scorecard-action/compare/v2.0.3...v2.0.4 Commits e363bfc Bump docker to next release. (#952) 65d491b :seedling: Bump codecov/codecov-action from 3.1.0 to 3.1.1 f60b7d6 :seedling: Bump github/codeql-action from 2.1.24 to 2.1.25 be7ddf6 :seedling: Bump github.com/sigstore/cosign from 1.12.0 to 1.12.1 9a2bfd4 :seedling: Bump actions/dependency-review-action from 2.1.0 to 2.4.0 (#950) a346ade 🐛 Restore behavior of ignoring scorecard runtime errors (#948) 2db2a1c :seedling: Bump github/codeql-action from 2.1.22 to 2.1.24 (#941) c858631 :seedling: Bump github.com/sigstore/cosign from 1.11.1 to 1.12.0 (#938) 8ee777f :seedling: Bump debian from 11.4-slim to 11.5-slim (#936) 6213479 feat: do not run signing on pull requests (#935) Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
