RSS Bot Posted October 3, 2022 Posted October 3, 2022 Bumps styfle/cancel-workflow-action from 0.10.0 to 0.10.1. Release notes Sourced from styfle/cancel-workflow-action's releases. 0.10.1 Patches Bump actions/setup-node from 3.3.0 to 3.4.0: #171 Bump actions/setup-node from 3.4.0 to 3.4.1: #172 Bump @actions/core from 1.9.0 to 1.9.1: #176 Bump typescript from 4.7.4 to 4.8.2: #177 Bump typescript from 4.8.2 to 4.8.3: #178 Bump @actions/github from 5.0.3 to 5.1.0: #179 Bump actions/setup-node from 3.4.1 to 3.5.0: #180 Chore: change access_token to optional: #72 Chore: update README.md to the correct version: #173 Chore: add README.md section about versioning: bb0138e6865a516b5413971879ceda1467fd2930 2c6e931f39ab183387be060414035511a22e69bd Credits Huge thanks to @licitdev and @MichaelDeBoey for helping! Commits 9f10b1b 0.10.1 2c6e931 chore: remove unnecessary version bb0138e Add section about versioning ceace68 chore: rebuild 7472485 chore: change access_token to optional (#72) 384c570 Bump actions/setup-node from 3.4.1 to 3.5.0 (#180) 591f48c Bump @actions/github from 5.0.3 to 5.1.0 (#179) da9a861 Bump typescript from 4.8.2 to 4.8.3 (#178) 2837f42 Bump typescript from 4.7.4 to 4.8.2 (#177) 0c4b4d7 Bump @actions/core from 1.9.0 to 1.9.1 (#176) Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
