[CNX-Software] - Allwinner V851S/V851SE low-cost camera SoC embeds 64MB DDR2, a 0.5 TOPS NPU
Allwinner V851S camera board
Allwinner V851S/V851SE is a single-core Arm Cortex-A7 SoC with a RISC-V core, an H.265/H.264 video encoder, and a 0.5 TOPS NPU designed for Smart IP cameras with support for features such as human detection and crossing alarms. Both processors ship with 64MB DDR2 memory, and feature USB, Ethernet, and SDIO interfaces, but the V851S is designed for systems with a display, while the V851SE targets traditional headless IP cameras. Both processors are pretty similar, but here are the key differences between Allwinner V851S: Networking – 10/100 Mbps Ethernet port with RMII interface GPIO – 6x ports (PA, PC, PD, PE, PF, PH) Display LCD Parallel RGB, Serial RGB, i8080, BT656 2-lane MIPI DSI SPI – 4x SPI and Allwinner V851SE: Networking – SIP 100 Mbps EPHY GPIO – 5x ports (PA, PC, PE, PF, PH) Display – Not supported SPI – 3x SPI That means the Allwinner V851S requires an [...]
The post Allwinner V851S/V851SE low-cost camera SoC embeds 64MB DDR2, a 0.5 TOPS NPU appeared first on CNX Software - Embedded Systems News.
View the full article
