RSS Bot Posted October 11, 2022 Posted October 11, 2022 Tuya T6E is a 4-inch control panel with a touchscreen running Android 8.1 on Rockchip PX30, WiFi, Bluetooth, and Zigbee, and designed to be wall-mounted for home automation and other HMI applications. It looks fairly similar to the ITEAD NSPanel Pro introduced last month, for Tuya’s “Central Control System” (CSS) appears to be mostly designed for OEMs who want to roll their own products with custom firmware. Tuya T6E specifications (details vary depending on OEM requirements): SoC – Rockchip PX30 quad-core Arm Cortex-A35 processor @ up to 1.5GHz with Mali-G31 MP2 GPU System Memory – 4GB RAM Storage – 4GB to 8GB eMMC flash Display – 4-inch 480×480 IPS screen with 5-point capacitive touch Audio Dual-array microphone with noise reduction 1 Watt speaker Connectivity 10/100Mbps Ethernet RJ45 port 2.4 GHz 802.11b/g/n Wi-Fi 4 Bluetooth LE 4.2 and Bluetooth Mesh (Tuya SigMesh) Zigbee 3.0 gateway based on Tuya TYZS13 module RS485 [...] The post Tuya “T6E” is a 4-inch Android touch control panel & Zigbee gateway for OEMs appeared first on CNX Software - Embedded Systems News. View the full article
