[Armbian build PR] - add fat bootfs to rock5b
Description
Although the u-boot of rock5b supports ext4, when using ext4 as a whole root partition, sometimes it will take a long time for u-boot to load kernel image, which will cause pd negotiation timeout. So a single /boot partition is still needed. I intended to use ext4 as boot partition filesystem but the ext4 /boot only has usable space 109M while the real partition size is 256M, so I use fat filesystem.
How Has This Been Tested?
  • [x] Build image sucessfully.
  • [x] Image boots successfully on rock5b
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
