[Armbian build PR] - Bump geekyeggo/delete-artifact from 1 to 2
Bumps geekyeggo/delete-artifact from 1 to 2.
Release notes
Sourced from geekyeggo/delete-artifact's releases.
v2.0.0 Glob support
🚨 Breaking
  • Artifact names are now matched using glob pattern matching by default.
Added
  • Add support for glob pattern matching (fulfilled by minimatch).
♻ Changed
  • Updated action to use node v16
  • Updated dependencies.
🏠 Housekeeping
  • Action is now written in TypeScript.
Commits
  • 54ab544 Add warning for glob support on by default
  • 3328f8f Merge pull request #10 from GeekyEggo/v2-wip
  • d546443 Update action info, and bump to node 16
  • 424f35a Add glob support, switch to TypeScript, and bump deps
  • 442f120 Update dev environment
  • 56e063d Added example workflow
  • b1df0e6 Removed watch cli dependency
  • See full diff in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
