RSS Bot Posted October 25, 2022 Posted October 25, 2022 Spotpear’s Raspberry Pi Zero 2 W to Raspberry Pi 3/4 adapters would not exist in a “normal” world of abundance that still existed a little less than 3 years ago. But I suppose extraordinary times require extraordinary adapters… If you have a spare Raspberry Pi Zero 2 W lying around but would rather like getting the ports from a Raspberry Pi 3 or Raspberry Pi 4, Spotpear has designed three adapters that can also be used as USB docks from a computer or mobile phone. The first adapter the “ZERO to 4B” will get you a Raspberry Pi 4-looking SBC with a Raspberry Pi RP3A0 system-in-package (Quad-core Cortex-A53 CPU + 512 MB RAM), and most of the same ports, except only three USB 2.0 Type-A ports are available with a maximum speed of 480 Mbps, and only one HDMI output due the inherent limitations of the Raspberry Pi Zero 2 [...] The post Adapters convert Raspberry Pi Zero 2 W into Raspberry Pi 3 or 4 appeared first on CNX Software - Embedded Systems News. View the full article
