Recently i've download and installed Armbian_22.08.7_Bananapim5_bullseye_edge_5.19.16_minimal.img into Banana Pi M5 board. Initial setup run smoothly. After run the reboot command the system stop halfway. Can I know how to solve this problem? I have copy the error message below. Thanks.
U-Boot 2022.07-armbian (Oct 18 2022 - 07:30:35 +0000)bpi-m5
Model: Banana Pi BPI-M5
SoC:   Amlogic Meson SM1 (S905X3) Revision 2b:c (10:2)
DRAM:  3.8 GiB
Core:  385 devices, 27 uclasses, devicetree: separate
MMC:   sd@ffe05000: 0, mmc@ffe07000: 1
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@ff3f0000
Autoboot in 2 seconds
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
8147 bytes read in 3 ms (2.6 MiB/s)
## Executing script at 08000000
U-boot default fdtfile: amlogic/meson-sm1-bananapi-m5.dtb
Current variant:
161 bytes read in 2 ms (78.1 KiB/s)
Current fdtfile after armbianEnv: amlogic/meson-sm1-bananapi-m5.dtb
Mainline bootargs: root=UUID=d0c122f6-b8a9-4650-94c2-77c85521b2d8 rootwait rootfstype=ext4 splash=verbose console=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=1 ubootpart=79a75e49-01 libata.force=noncq usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u    cgroup_enable=memory swapaccount=1
19116246 bytes read in 838 ms (21.8 MiB/s)
mmc fail to send stop cmd
 ** fs_devread read error - block
Failed to load '/boot/Image'
Failed to mount ext2 filesystem...
Can't set block device
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
## Loading init Ramdisk from Legacy Image at 13000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    19116182 Bytes = 18.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
** No partition table - mmc 0 **
Couldn't find partition mmc 0:1
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
mmc1(part 0) is current device
** No partition table - mmc 1 **
Couldn't find partition mmc 1:1
MMC Device 2 not found
no mmc device at slot 2
starting USB...
Bus usb@ff500000: Register 3000140 NbrPorts 3
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices... 3 USB Device(s) found
Device 0: unknown device
Speed: 100, full duplex
BOOTP broadcast 1
DHCP client bound to address 192.168.0.156 (12 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
Retrieving file: pxelinux.cfg/01-ba-df-83-51-8d-a0
Retrieving file: pxelinux.cfg/C0A8009C
Retrieving file: pxelinux.cfg/default-arm-meson-u200
Config file not found
BOOTP broadcast 1
DHCP client bound to address 192.168.0.156 (2 ms)
BOOTP broadcast 1
