RSS Bot Posted November 16, 2022 Posted November 16, 2022 Description The BUILD_ONLY option can be set as a comma separated list of build artifact names to filter build artifacts being compiled. The following artifact names are supported: u-boot, kernel, armbian-config, armbian-zsh, plymouth-theme-armbian, armbian-firmware, armbian-bsp, chroot, bootstrap GH issue reference #4421 Test Results Following tests have been performed with the according output: [x] Test 1 - U-Boot only build - BUILD_ONLY="u-boot": ./compile.sh BOARD=cubietruck BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no BUILD_ONLY="u-boot" KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,7z ... MKIMAGE u-boot.img MKIMAGE u-boot-dtb.img BINMAN all [ o.k. ] Building deb [ linux-u-boot-current-cubietruck_22.11.0-trunk_armhf.deb ] [ o.k. ] Build done [ @host ] [ o.k. ] Target directory [ /home/user/Projects/Armbian/build/output/debs/ ] [ o.k. ] U-Boot file name [ linux-u-boot-current-cubietruck_22.11.0-trunk_armhf.deb ] [ o.k. ] Runtime [ 0 min ] [ o.k. ] Repeat Build Options [ ./compile.sh BOARD=cubietruck BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no BUILD_ONLY=u-boot KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,7z ] user@HOST:~/Projects/Armbian/build$ [x] Test 2 - Kernel only build - BUILD_ONLY="kernel": ./compile.sh BOARD=cubietruck BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no BUILD_ONLY="kernel" KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,7z ... CLEAN vmlinux.symvers modules-only.symvers modules.builtin modules.builtin.modinfo patching file tools/include/tools/be_byteshift.h patching file tools/include/tools/le_byteshift.h dpkg-deb: building package 'linux-headers-current-sunxi' in '../linux-headers-current-sunxi_22.11.0-trunk_armhf.deb'. dpkg-buildpackage: info: binary-only upload (no source included) [ o.k. ] Build done [ @host ] [ o.k. ] Target directory [ /home/user/Projects/Armbian/build/output/debs/ ] [ o.k. ] Kernel file name [ linux-image-current-sunxi_22.11.0-trunk_armhf.deb ] [ o.k. ] Runtime [ 7 min ] [ o.k. ] Repeat Build Options [ ./compile.sh BOARD=cubietruck BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no BUILD_ONLY=kernel KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,7z ] user@HOST:~/Projects/Armbian/build$ [x] Test 3 - Kernel only build - BUILD_ONLY not set, KERNEL_ONLY=yes: ./compile.sh BOARD=cubietruck BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=yes KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,7z ... patching file tools/include/tools/le_byteshift.h dpkg-deb: building package 'linux-headers-current-sunxi' in '../linux-headers-current-sunxi_22.11.0-trunk_armhf.deb'. dpkg-buildpackage: info: binary-only upload (no source included) [ o.k. ] Building deb [ armbian-config ] [ o.k. ] Checking git sources [ armbian-config master ] [ .... ] Up to date [ o.k. ] Checking git sources [ neofetch 7.1.0 ] [ .... ] Up to date [ o.k. ] Checking git sources [ wireguard-manager main ] [ .... ] Up to date [ o.k. ] * applying add-armbian-neofetch.patch [ o.k. ] Building deb [ armbian-zsh ] [ o.k. ] Checking git sources [ oh-my-zsh master ] [ .... ] Up to date [ o.k. ] Checking git sources [ evalcache master ] [ .... ] Up to date [ o.k. ] Building deb [ armbian-plymouth-theme ] [ o.k. ] Merging and packaging linux firmware [ @host ] [ o.k. ] Checking git sources [ armbian-firmware-git master ] [ .... ] Up to date [ o.k. ] Building firmware package [ armbian-firmware_22.11.0-trunk_all ] [ o.k. ] Merging and packaging linux firmware [ @host ] [ o.k. ] Checking git sources [ armbian-firmware-git master ] [ .... ] Up to date [ o.k. ] Checking git sources [ linux-firmware-git main ] [ .... ] Up to date [ o.k. ] Building firmware package [ armbian-firmware-full_22.11.0-trunk_all ] [ o.k. ] Creating board support package for CLI [ armbian-bsp-cli-cubietruck ] [ o.k. ] Build done [ @host ] [ o.k. ] Target directory [ /home/user/Projects/Armbian/build/output/debs/ ] [ o.k. ] U-Boot file name [ linux-u-boot-current-cubietruck_22.11.0-trunk_armhf.deb ] [ o.k. ] Kernel file name [ linux-image-current-sunxi_22.11.0-trunk_armhf.deb ] [ o.k. ] Runtime [ 10 min ] [ o.k. ] Repeat Build Options [ ./compile.sh BOARD=cubietruck BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=yes KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,7z ] user@HOST:~/Projects/Armbian/build$ [x] Test 4 - Full build - BUILD_ONLY not set, KERNEL_ONLY=no: ./compile.sh BOARD=cubietruck BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,7z ... patching file tools/include/tools/le_byteshift.h dpkg-deb: building package 'linux-headers-current-sunxi' in '../linux-headers-current-sunxi_22.11.0-trunk_armhf.deb'. dpkg-buildpackage: info: binary-only upload (no source included) [ o.k. ] Building deb [ armbian-config ] [ o.k. ] Checking git sources [ armbian-config master ] [ .... ] Up to date [ o.k. ] Checking git sources [ neofetch 7.1.0 ] [ .... ] Up to date [ o.k. ] Checking git sources [ wireguard-manager main ] [ .... ] Up to date [ o.k. ] * applying add-armbian-neofetch.patch [ o.k. ] Building deb [ armbian-zsh ] [ o.k. ] Checking git sources [ oh-my-zsh master ] [ .... ] Up to date [ o.k. ] Checking git sources [ evalcache master ] [ .... ] Up to date [ o.k. ] Building deb [ armbian-plymouth-theme ] [ o.k. ] Merging and packaging linux firmware [ @host ] [ o.k. ] Checking git sources [ armbian-firmware-git master ] [ .... ] Up to date [ o.k. ] Building firmware package [ armbian-firmware_22.11.0-trunk_all ] [ o.k. ] Merging and packaging linux firmware [ @host ] [ o.k. ] Checking git sources [ armbian-firmware-git master ] [ .... ] Up to date [ o.k. ] Checking git sources [ linux-firmware-git main ] [ .... ] Up to date [ o.k. ] Building firmware package [ armbian-firmware-full_22.11.0-trunk_all ] [ o.k. ] Creating board support package for CLI [ armbian-bsp-cli-cubietruck ] [ o.k. ] Checking for rootfs cache [ current cubietruck focal yes ] [ o.k. ] Checking cache [ armhf-focal-minimal-fac994d6-20221112.tar.zst ] [ o.k. ] Extracting armhf-focal-minimal-fac994d6-20221112.tar.zst [ 4 days old ] [ .... ] armhf-focal-minimal-fac994d6-20221112.tar.zst: 128MiB [75.5MiB/s] [==========================================================================>] 100% [ o.k. ] Adding Armbian repository and authentication key [ /etc/apt/sources.list.d/armbian.list ] [ o.k. ] Applying distribution specific tweaks for [ focal ] [ o.k. ] Configuring locales [ en_US.UTF-8 ] Generating locales (this might take a while)... en_US.UTF-8... done Generation complete. [ o.k. ] Applying common tweaks [ .... ] Cleaning [ package lists ] [ .... ] Updating [ package lists ] [ .... ] Temporarily disabling [ initramfs-tools hook for kernel ] [ .... ] Installing [ linux-u-boot-current-cubietruck_22.11.0-trunk_armhf.deb ] [ .... ] Installing [ linux-image-current-sunxi_22.11.0-trunk_armhf.deb ] [ .... ] Installing [ linux-dtb-current-sunxi_22.11.0-trunk_armhf.deb ] [ .... ] Installing [ armbian-bsp-cli-cubietruck_22.11.0-trunk_armhf.deb ] [ .... ] Installing [ armbian-firmware_22.11.0-trunk_all.deb ] [ .... ] Installing [ armbian-plymouth-theme_22.11.0-trunk_all.deb ] [ .... ] Installing from repository [ wireguard-tools --no-install-recommends ] [ o.k. ] Enabling serial console [ 'ttyS0' ] [ o.k. ] Building kernel splash logo [ focal ] [ .... ] Installing extras-buildpkgs [ hostapd htop sunxi-tools ] [ o.k. ] Copying NAND boot files to image [ customize-image-host.sh ] '/home/user/Projects/Armbian/build/cache/sources/u-boot/v2022.07/spl/sunxi-spl-with-ecc.bin' -> '/home/user/Projects/Armbian/build/userpatches/overlay/boot/nand/sunxi-spl-with-ecc.bin' '/home/user/Projects/Armbian/build/cache/sources/u-boot/v2022.07/u-boot-dtb.img' -> '/home/user/Projects/Armbian/build/userpatches/overlay/boot/nand/u-boot-dtb.img' [ o.k. ] Calling image customization script [ customize-image.sh ] '/tmp/overlay/boot/nand' -> '/boot/nand' '/tmp/overlay/boot/nand/sunxi-spl-with-ecc.bin' -> '/boot/nand/sunxi-spl-with-ecc.bin' '/tmp/overlay/boot/nand/u-boot-dtb.img' -> '/boot/nand/u-boot-dtb.img' [ o.k. ] No longer needed packages [ purge ] [ o.k. ] Unmounting [ /home/user/Projects/Armbian/build/.tmp/rootfs-7d834edd-2750-4d7e-83b2-816029998099 ] [ o.k. ] Preparing image file for rootfs [ cubietruck focal ] [ o.k. ] Current rootfs size [ 681 MiB ] [ o.k. ] Creating blank image for rootfs [ 892 MiB ] [ o.k. ] Creating partitions [ root: ext4 ] [ .... ] Creating rootfs [ ext4 on /dev/loop0p1 ] [ .... ] Copying files to [ / ] [ .... ] Copying files to [ /boot ] sent 19.10M bytes received 4.82K bytes 38.21M bytes/sec total size is 19.08M speedup is 1.00 [ .... ] Updating initramfs... [ TMPDIR=/tmp update-initramfs -uv -k 5.15.77-sunxi ] [ o.k. ] Updated initramfs. [ for details see: /home/user/Projects/Armbian/build/output/debug/install.log ] [ .... ] Re-enabling [ initramfs-tools hook for kernel ] [ o.k. ] Unmounting [ /home/user/Projects/Armbian/build/.tmp/mount-7d834edd-2750-4d7e-83b2-816029998099/ ] [ o.k. ] Free SD cache [ 20% ] [ o.k. ] Mount point [ 88% ] [ o.k. ] Writing U-boot bootloader [ /dev/loop0 ] [ o.k. ] SHA256 calculating [ Armbian_22.11.0-trunk_Cubietruck_focal_current_5.15.77_minimal.img ] [ warn ] GPG signing skipped - no GPG_PASS [ Armbian_22.11.0-trunk_Cubietruck_focal_current_5.15.77_minimal.img ] [ o.k. ] Compressing [ /home/user/Projects/Armbian/build/.tmp/image-7d834edd-2750-4d7e-83b2-816029998099/Armbian_22.11.0-trunk_Cubietruck_focal_current_5.15.77_minimal.7z ] [ o.k. ] Done building [ /home/user/Projects/Armbian/build/.tmp/image-7d834edd-2750-4d7e-83b2-816029998099/Armbian_22.11.0-trunk_Cubietruck_focal_current_5.15.77_minimal.img ] [ o.k. ] Build done [ @host ] [ o.k. ] Target directory [ /home/user/Projects/Armbian/build/output/debs/ ] [ o.k. ] U-Boot file name [ linux-u-boot-current-cubietruck_22.11.0-trunk_armhf.deb ] [ o.k. ] Kernel file name [ linux-image-current-sunxi_22.11.0-trunk_armhf.deb ] [ o.k. ] Runtime [ 15 min ] [ o.k. ] Repeat Build Options [ ./compile.sh BOARD=cubietruck BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,7z ] user@HOST:~/Projects/Armbian/build$ Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] I will create an appropriate pull request on the doc repo as soon as this PR has been merged [x] My changes generate no new warnings [n/a] Any dependent changes have been merged and published in downstream modules View the full article
