[CNX-Software] - MediaTek Kompanio 520 and Kompanio 528 processors targets entry-level Chromebooks
MediaTek Kompanio 528
MediaTek Kompanio 520 and Kompanio 528 octa-core Arm processors are designed for entry-level Chromebooks with all-day battery life and a display up to 2520 x 1080 resolutions. As time passes “entry-level” gets a new meaning as the new SoCs are equipped with two Cortex-A76 cores @ up to 2.2 GHz, six Cortex-A55 cores @ 2.0 GHz, and an Arm Mali-G52 GPU. That’s almost Rockchip RK3588 territory although not quite… MediaTek Kompanio 528 and 520 specifications: Octa-core CPU 2x Arm Cortex-A76 cores up to 2.2GHz (Kompanio 520 is limited to 2.0 GHz) 6x Arm Cortex-A55 cores up to 2GHz GPU – Arm Mali G52 MC2 2EE AI accelerator – Dual-core AI processing unit (APU) Memory –  LPDDR4x up to 3733Mbps Storage – eMMC 5.1 flash with hardware command queue Display 2520 x 1080 @ 60Hz 1920 x 1080 @ 60Hz (Ext) Video Encoding – 1920 x 1080 @ 60fps H.264 or [...]
The post MediaTek Kompanio 520 and Kompanio 528 processors targets entry-level Chromebooks appeared first on CNX Software - Embedded Systems News.
View the full article
