ari1234 Posted November 19, 2022 Posted November 19, 2022 (edited) i used this python script to read matrix 4x4 keypad data to raspberry pi import RPi.GPIO as GPIO #raspberry pi import time # these GPIO pins are connected to the keypad RPI L1 = 21 L2 = 23 L3 = 27 L4 = 29 C1 = 31 C2 = 33 C3 = 35 C4 = 37 # Initialize the GPIO pins GPIO.setwarnings(False) GPIO.setmode(GPIO.BCM) GPIO.setup(L1, GPIO.OUT) GPIO.setup(L2, GPIO.OUT) GPIO.setup(L3, GPIO.OUT) GPIO.setup(L4, GPIO.OUT) # Make sure to configure the input pins to use the internal pull-down resistors GPIO.setup(C1, GPIO.IN, pull_up_down=GPIO.PUD_DOWN) GPIO.setup(C2, GPIO.IN, pull_up_down=GPIO.PUD_DOWN) GPIO.setup(C3, GPIO.IN, pull_up_down=GPIO.PUD_DOWN) GPIO.setup(C4, GPIO.IN, pull_up_down=GPIO.PUD_DOWN) # It sends out a single pulse to one of the rows of the keypad # and then checks each column for changes # If it detects a change, the user pressed the button that connects the given line # to the detected column def readLine(line, characters): GPIO.output(line, GPIO.HIGH) if(GPIO.input(C1) == 1): print(characters[0]) if(GPIO.input(C2) == 1): print(characters[1]) if(GPIO.input(C3) == 1): print(characters[2]) if(GPIO.input(C4) == 1): print(characters[3]) GPIO.output(line, GPIO.LOW) try: while True: # call the readLine function for each row of the keypad readLine(L1, ["1","2","3","e"]) readLine(L2, ["4","5","6","r"]) readLine(L3, ["7","8","9","t"]) readLine(L4, ["q","0","w","y"]) time.sleep(0.2) except KeyboardInterrupt: print("\nApplication stopped!") How can i create similar script for orange pi in armbian (in my case orange pi pc plus)? it can by python or other language doesnt matter Edited November 19, 2022 by ari1234 0 Quote
