[Armbian build PR] - Fix basic host preparation when running on Docker
When running in Docker, do not install basic utilities on the host. Do not install them in the container either, as they're already part of the image we're building for Docker runs.
Description
I also moved the whole if block in compile.sh down to a place where $1 is guaranteed to have attained its final value (e.g. if compile.sh dockerpurge was called).
How Has This Been Tested?
  • [x] ran compile.sh docker and verified it installs nothing on the host
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
