[Armbian build PR] - SUNXI: Update setting of UBOOT_TARGET_MAP to allow overiding
Description
UBOOT_TARGET_MAP in config\sources\families\include\sunxi_common.inc and in config\sources\families\include\sunxi64_common.inc has been changed to use the original definition as default to allow overriding from an already existing definition of UBOOT_TARGET_MAPby e.g. a board configuration file.
Issue reference: #4478
Test results
This has been tested by a build process for a Cubietruck board. File content of config/boards/cubietruck.csc:
# Allwinner A20 dual core 2GB RAM SoC 1xSATA GBE WiFi/BT
BOARD_NAME="Cubietruck"
BOARDFAMILY="sun7i"
BOOTCONFIG="Cubietruck_config"
KERNEL_TARGET="legacy,current,edge"
UBOOT_TARGET_MAP=";;u-boot-sunxi-with-spl.bin spl/sunxi-spl-with-ecc.bin:u-boot-sunxi-nand-spl-with-ecc.bin u-boot-dtb.img"
  • [x] Test succeeded for a Cubietruck board build with UBOOT_TARGET_MAP defined in config/boards/cubietruck.csc
Checklist:
  • [n/a] I have commented my code, particularly in hard-to-understand areas
  • [n/a] I have made corresponding changes to the documentation
  • [n/a] Any dependent changes have been merged and published in downstream modules
View the full article
