RSS Bot Posted November 29, 2022 Posted November 29, 2022 Allwinner V3LP is a single-core Cortex-A7 processor for dual-camera systems with the exact same specifications as the Allwinner V3S processor introduced in 2016, except it should be more power efficient with a lower DDR operating voltage of 1.5V instead of 1.8V. Sochip explains that procuring the integrated DDR2 in the Allwinner V3s design is challenging, so Allwinner has replaced the memory in the pin-to-pin compatible Allwinner V3LP with more broadly available and lower power RAM. Allwinner V3LP specifications: CPU – ARM Cortex-A7 @ up to 1.2 GHz Memory – Integrated 64MB DDR2 DRAM @ 1.5 V Storage I/F – SD 2.0, eMMC 4.41, SPI NAND flash, SPI NOR flash Audio Codec – 92dB audio codec supporting 2x ADC channels and 2x DAC channels, 1x low-noise analog microphone bias output, 1x microphone input and 1x stereo microphone output Video Processing Unit Encoding – 1080p@40fps or 1080p@30fps + VGA@30fps H.264 Decoding – [...] The post Allwinner V3LP gets low voltage RAM, should replace Allwinner V3S dual camera SoC appeared first on CNX Software - Embedded Systems News. View the full article
