Kein Posted March 8 Posted March 8 Thanks for all of your help! I use the stable version(Armbian_23.2.1_Rock-5b_jammy_legacy_5.10.160_xfce-amazingfated_desktop), and following the instructions add ppa and install kodi. It works so much better, chromium-browser plays youtube 4K movies very well. But when I add add-on for youtuber, I got errors like inputstream.adaptive not available. I check like this: ------------------------------------------------------------------------------------ kein@rock-5b:~$ sudo apt info kodi-inputstream-adaptive [sudo] password for kein: Package: kodi-inputstream-adaptive Version: 19.0.0+ds1-2 Priority: optional Section: universe/libs Origin: Ubuntu Maintainer: Ubuntu Developers Original-Maintainer: Debian Multimedia Maintainers Bugs: https://bugs.launchpad.net/ubuntu/+filebug Installed-Size: 2,372 kB Depends: libc6 (>= 2.34), libexpat1 (>= 2.0.1), libgcc-s1 (>= 3.3.1), libstdc++6 (>= 11), libwebm1 (>= 1.0.0.28), kodi-api-inputstream (> = 3.0.1), kodi-api-inputstream ( Homepage: https://kodi.tv/ Download-Size: 574 kB APT-Sources: http://ports.ubuntu.com jammy/universe arm64 Packages Description: Adaptive inputstream addon for Kodi ------------------------------------------------------------- But the problems is that package "kodi-api-inputstream" is not available at all. Any hints? 0 Quote
peter.eismann Posted May 3 Posted May 3 (edited) Hi @Kein, I made good expierience in building kodi and the inputstream.adaptive - addon from the sources on github and not using the repository versions. Edited May 3 by peter.eismann 0 Quote
peter.eismann Posted May 3 Posted May 3 (edited) @amazingfate I have one problem with the netflix addon though. It displays a green overlay "fog". Everything else works, I have the Amazon VOD addon working, the Disney+ addon works, I can play H264 as well as 4K HEVC videos with hardware acceleration. Does anyone expierence the same with Netflix? Another thing is, that I have only one working rock 5b image. I have created it myself from armbian with the legacy kernel 5.10.160 as I need custom gpio overlays for using an IR receiver where the driver needs to be activated in the kernel. After that I installed everything based on the howtos for the Rock 5b. I built MPP, RGA, FFMPEG and Kodi and got real nice hardware accelleration. I could, however, never reproduce it to create a current how to. I tried using an edge kernel where the UARTs are supposed to be working and other features should be enabled, but when I start Kodi in a Wayland session I get this: with the following errors in syslog: May 3 12:03:02 rock-5b kernel: [ 185.881239] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 May 3 12:03:02 rock-5b kernel: [ 185.881258] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 May 3 12:03:02 rock-5b kernel: [ 185.881265] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 May 3 12:03:02 rock-5b kernel: [ 185.881271] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 May 3 12:03:02 rock-5b kernel: [ 185.881278] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 May 3 12:03:02 rock-5b kernel: [ 185.881284] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 May 3 12:03:02 rock-5b kernel: [ 185.881299] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 May 3 12:03:02 rock-5b kernel: [ 185.881306] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 May 3 12:03:02 rock-5b kernel: [ 185.881312] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 May 3 12:03:02 rock-5b kernel: [ 185.881319] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 May 3 12:03:07 rock-5b kernel: [ 190.882731] vop2_isr: 198389 callbacks suppressed I don't know what the difference is. I also get that behaviour using the same base image that is working in a new install. Up to now I did not find anything usefull with google or here in the forums. Maybe someone has seen it and can point me somewhere. Thanks Peter Edited May 3 by peter.eismann 0 Quote
amazingfate Posted May 3 Author Posted May 3 @peter.eismann I don't know about the netflix issue and I can't confirm that. Kodi does not run well inside a wayland session. You can try to login to a gbm session from display manager. 0 Quote
peter.eismann Posted May 6 Posted May 6 (edited) so, I tried it again with the kernel 6.1.43 and with the instructions from the howto. That resulted in the scrambled picture when opening kodi. (see above post) Then I built mpp, rga, ffmpeg_rockchip and kodi new. After a restart I could not open kodi as it complained about the missing fbdev module. Then I build drm-package and the mesa driver again. Then kodi opened again only to give the following errors when opening a movie: 2024-05-06 09:43:53.882 T:6596 info <general>: Creating InputStream 2024-05-06 09:43:53.916 T:6596 info <general>: Creating Demuxer 2024-05-06 09:43:53.990 T:6596 info <general>: Opening stream: 0 source: 256 2024-05-06 09:43:53.990 T:6596 info <general>: Creating video codec with codec id: 173 2024-05-06 09:43:53.990 T:6596 info <general>: CDVDVideoCodecDRMPRIME::Open - using decoder Rockchip MPP (Media Process Platform) HEVC decoder 2024-05-06 09:43:53.991 T:6596 info <general>: Creating video thread 2024-05-06 09:43:53.991 T:6600 info <general>: running thread: video_thread 2024-05-06 09:43:53.992 T:6596 info <general>: Opening stream: 1 source: 256 2024-05-06 09:43:53.992 T:6596 info <general>: Finding audio codec for: 86060 2024-05-06 09:43:53.992 T:6596 info <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder truehd 2024-05-06 09:43:53.992 T:6596 info <general>: OpenStream: Allowing max Out-Of-Sync Value of 10 ms 2024-05-06 09:43:53.992 T:6596 info <general>: Creating audio thread 2024-05-06 09:43:53.992 T:6601 info <general>: running thread: CVideoPlayerAudio::Process() 2024-05-06 09:43:53.992 T:6596 info <general>: Opening stream: 9 source: 256 2024-05-06 09:43:54.003 T:6601 info <general>: Creating audio stream (codec id: 86060, channels: 8, sample rate: 48000, no pass-through) 2024-05-06 09:43:54.032 T:1329 error <general>: CEGLImage::SupportsFormat - format not supported: YU10 2024-05-06 09:43:54.033 T:1329 info <general>: GLES: Selecting single pass rendering 2024-05-06 09:43:54.033 T:1329 info <general>: GLES: Selecting YUV 2 RGB shader 2024-05-06 09:43:54.033 T:1329 error <general>: CBaseRenderer::GetShaderFormat - unsupported format 179 2024-05-06 09:43:54.033 T:1329 error <general>: GLES: BaseYUV2RGBGLSLShader - unsupported format none 2024-05-06 09:43:54.034 T:1674 info <general>: Skipped 1 duplicate messages.. So this means, that the original howto's for Rock 5b do not work anymore. And I did not find any working or reproducible collection of steps needed to get kodi reliably working with hw acceleration. This is quite a nightmare. I have this thing for over a year now and i am not able to use it. Edited May 6 by peter.eismann 0 Quote
amazingfate Posted May 13 Author Posted May 13 @peter.eismannYou are using EGL as render method, which will only support NV12 format. You can try direct-to-plane. 0 Quote
peter.eismann Posted May 13 Posted May 13 (edited) @amazingfateI finally made some progress. I've got a working 6.1.43 kernel with Ubuntu noble and the newest versions of Kodi and Inputstream adaptive. I have used the vendor-boogie-panthor configuration for armbian and added my IR Receiver settings. Unfortunately with Netflix the WivedineCDM lib does not work as the patches for glibc6 are missing. I know there is a patched version in your PPA, but since I use noble instead of jammy I was wondering what I need to do to build a patched libc6 myself. Do you remember how you built it? (glibc=1:2.35-0ubuntu3.4+2widevine) Edited May 13 by peter.eismann 0 Quote
amazingfate Posted May 13 Author Posted May 13 @peter.eismann I added patches to glibc: https://launchpad.net/~liujianfeng1994/+archive/ubuntu/rockchip-multimedia/+sourcefiles/glibc/1:2.35-0ubuntu3.4+2widevine/glibc_2.35-0ubuntu3.4+2widevine.debian.tar.xz But it seems that this patch is no longer needed with newer glibc: https://aur.archlinux.org/packages/widevine 0 Quote
peter.eismann Posted May 13 Posted May 13 that did it, it works now and I don't have that green pricture anymore. Thanks a lot. 0 Quote
