Recommanded ways to change the default overlays at build time
Go to solution Solved by schwar3kat,
Hi!
I need to use the UART1 port on my NanoPi NEO. This usually means just adding "uart1" to the `overlays` in `/boot/armbianEnv.txt`.
What I would like to do is build a custom image that already has the overlay activated by default.
I read the following documentations:
- https://docs.armbian.com/User-Guide_Armbian_overlays/
- https://docs.armbian.com/Developer-Guide_User-Configurations/
But couldn't find anything about it.
At first I tried to define the `DEFAULT_OVERLAYS` env var in `userpatches/config-example.conf` since I noticed it was defined in the configuration for the board, but it didn't work.
I manage to make it work by modifying the `armbianEnv.txt` file within the `customize-image.sh` script, using some sed magic. For exemple:
RELEASE=$1
LINUXFAMILY=$2
BOARD=$3
BUILD_DESKTOP=$4
Main() {
        echo "Release: $RELEASE"
        case $RELEASE in
                jammy)
                        DisplayArmbianBootConf
        esac
} # Main
DisplayArmbianBootConf() {
echo "Adding UART1 overlay"
sed -i '/overlays/s/$/ uart1/' /boot/armbianEnv.txt
echo "armbianEnv.txt: "
cat /boot/armbianEnv.txt
echo "UART1 added."
Now this works fine, but it feels a bit "hackish".
So I was wondering, is there a better way to achieve this ? This I miss an env var, conf file or specific configuration which would allow me to append overlays to the default overlay of the board ?
Thanks,
  • Solution
Expand
In my opinion, for what it's worth :), that's exactly the sort of thing customize-image.sh is intended to be used for.
It's arguably less "hackish" than many other hacks, because it is intended for the purpose.
Hello !
In this case, and seeing that no one else propose a better solution, I will mark you answer a solution.
It's a bit sad that the board configuration do define a `DEFAULT_OVERLAYS` but it doesn't seem that we can override it.
But the customize-image.sh solution do work pretty well, so definitely not a big deal.
