RSS Bot Posted December 5, 2022 Posted December 5, 2022 Description Add collective target "default" The BUILD_ONLY variable should not be empty, that is, the target for the assembly should be defined. If this is not the case, open a selection dialog with marked goals that correspond to the default collective goal. This work provides an opportunity for the implementation of the choice dialog. Checklist: [ ] Test build View the full article
