Bluetooth stopped working in kernel  5.19.17-meson64 #22.11.1
root@nextcloudpi:~# hciconfig
hci0:   Type: Primary  Bus: USB
        BD Address: 00:00:00:00:00:00  ACL MTU: 0:0  SCO MTU: 0:0
        DOWN
        RX bytes:14 acl:0 sco:0 events:1 errors:0
        TX bytes:3 acl:0 sco:0 commands:3 errors:2
root@nextcloudpi:~# hcitool dev
Devices:
root@nextcloudpi:~# dmesg | grep Bluetooth
[   10.005353] Bluetooth: Core ver 2.22
[   10.010561] Bluetooth: HCI device and connection manager initialized
[   10.010582] Bluetooth: HCI socket layer initialized
[   10.010589] Bluetooth: L2CAP socket layer initialized
[   10.010621] Bluetooth: SCO socket layer initialized
[   10.273422] Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
[   11.647454] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   11.647474] Bluetooth: BNEP filters: protocol multicast
[   11.647489] Bluetooth: BNEP socket layer initialized
[   15.326913] Bluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround
[   15.327136] Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported.
[   15.327149] Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported.
[   15.327153] Bluetooth: hci0: HCI Set Event Filter command not supported.
[   17.341929] Bluetooth: hci0: Opcode 0x c03 failed: -110
[42900.593231] Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
[42900.922097] Bluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround
[42900.923021] Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported.
[42900.923040] Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported.
[42900.923044] Bluetooth: hci0: HCI Set Event Filter command not supported.
[42902.934227] Bluetooth: hci0: Opcode 0x c03 failed: -110
[42905.073243] Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
[42905.661928] Bluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround
[42905.662099] Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported.
[42905.662108] Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported.
[42905.662112] Bluetooth: hci0: HCI Set Event Filter command not supported.
