RSS Bot Posted December 9, 2022 Posted December 9, 2022 Description This script calls amixer to set various mixer volumes, by simply trying a bunch of mixer names for each sound card in the system. In practice, this meant the amixer command was called 158 times for each sound card. The overhead of all these forks and probably also amixer startup added together to produce a noticable slowdown in startup. For example on an Orange Pi PC, the script took about 6 seconds per soundcard. This was on a system with a few extra USB soundcards (6 alsa cards in total): $ time bash ./armbian-audio-config.original real 0m35.662s user 0m20.145s sys 0m15.145s This commit modifies the script to spawn amixer only once per alsa card, passing all the mixer set commands through stdin. This pretty much completely kills the slowdown. On the same 6-card system: $ time bash ./armbian-audio-config real 0m0.406s user 0m0.345s sys 0m0.229s How Has This Been Tested? Copied the script onto an existing system and running it manually. Changed some mixer controls with alsamixer, ran the script an confirmed they were changed back to 100%. Have not tested a full image build, but I cannot see how this would not work. Checklist: [X] My code follows the style guidelines of this project [X] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas - N/A [ ] I have made corresponding changes to the documentation - N/A [X] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules - N/A View the full article
