Skip to content
View in the app
Armbian Community Forums
[Armbian build PR] - Bump tj-actions/changed-files from 34 to 35
Featured Replies
Bumps tj-actions/changed-files from 34 to 35.
Release notes
Sourced from tj-actions/changed-files's releases.
v35
Changes in v35.0.1
What's Changed
Full Changelog: https://github.com/tj-actions/changed-files/compare/v35...v35.0.1
Changes in v35.0.0
🔥 🔥 BREAKING CHANGE 🔥 🔥
  • Removed input max_fetch_depth
What's Changed
Full Changelog: https://github.com/tj-actions/changed-files/compare/v34...v35.0.0
v35.0.0
What's Changed
v34.6.2
What's Changed
... (truncated)
Changelog
Sourced from tj-actions/changed-files's changelog.
v35 (2022-12-19)
Full Changelog
Implemented enhancements:
  • Changed lines of modified files #858
Merged pull requests:
v35.0.0 (2022-12-19)
Full Changelog
Fixed bugs:
  • [BUG] Process completed with exit code 1 #884
  • [BUG] changed-files error during run #875
Closed issues:
  • How to see the changed files after the PR is merged ? #874
v34.6.2 (2022-12-16)
Full Changelog
Commits
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
