[Armbian build PR] - Enable ISCSI_TCP for Rock 5b
Description
I have a number of other single board computers that are connected to a kubernetes cluster running Longhorn for storage. I want to be able to add my new Rock 5B to the same cluster. I quickly found that the kernel doesn't have support for ISCSI_TCP.
This support was added for all other boards in https://github.com/armbian/build/pull/2300.
How Has This Been Tested?
I built a custom kernel with this configuation using ``` ./compile.sh RELEASE=bullseye BOARD=rock-5b BRANCH=legacy BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_ONLY=yes KERNEL_CONFIGURE=no
I then installed the image and headers packages
sudo dpkg -i linux-image-legacy-rockchip-rk3588_23.02.0-trunk_arm64.deb sudo dpkg -i linux-headers-legacy-rockchip-rk3588_23.02.0-trunk_arm64.deb
Finally I installed open-iscsi
sudo apt install open-iscsi
# Checklist:
- [ ] My code follows the style guidelines of this project
- [x] I have performed a self-review of my own code
- [ ] I have commented my code, particularly in hard-to-understand areas
- [ ] I have made corresponding changes to the documentation
- [x] My changes generate no new warnings
- [ ] Any dependent changes have been merged and published in downstream modules
View the full article
