[Armbian build PR] - Bump ossf/scorecard-action from 2.1.0 to 2.1.2
Bumps ossf/scorecard-action from 2.1.0 to 2.1.2.
Release notes
Sourced from ossf/scorecard-action's releases.
v2.1.2
What's Changed
Fixes
Full Changelog: https://github.com/ossf/scorecard-action/compare/v2.1.1...v2.1.2
v2.1.1
Scorecard version
This release use Scorecard's v4.10.1
Full Changelog: https://github.com/ossf/scorecard-action/compare/v2.1.0...v2.1.1
Commits
  • e38b190 Bump docker tag for release. (#1055)
  • 7da02bf Bump scorecard to v4.10.2 to remove a CODEOWNERS printf statement. (#1054)
  • 013c0f8 :seedling: Bump actions/dependency-review-action from 3.0.1 to 3.0.2
  • f93c094 :seedling: Bump github/codeql-action from 2.1.36 to 2.1.37
  • ce8978e :seedling: Bump actions/upload-artifact from 3.1.0 to 3.1.1
  • 5ce49db :seedling: Bump actions/setup-go from 3.4.0 to 3.5.0
  • 15c10fc Update tag to v2.1.1 (#1047)
  • f96da1a :seedling: Update scorecard for the panic (#1045)
  • 813a825 Complete the list of required actions (#1044)
  • be62ea8 Update RELEASE.md (#1042)
  • Additional commits viewable in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
