[Armbian build PR] - Enable rtl8822cs in meson64-edge kernel
In researching a post in the forums, I found that the meson64-edge kernel config doesn't include rtl8822cs (which apparently some TV boxes use). This is enabled in most kernel configs:
linux-bcm2711-current.config:CONFIG_RTL8822CS=m linux-bcm2711-edge.config:CONFIG_RTL8822CS=m linux-imx6-current.config:CONFIG_RTL8822CS=m linux-imx6-edge.config:CONFIG_RTL8822CS=m linux-media-current.config:CONFIG_RTL8822CS=m linux-media-edge.config:CONFIG_RTL8822CS=m linux-media-legacy.config:# CONFIG_RTL8822CS is not set linux-meson64-current.config:CONFIG_RTL8822CS=m linux-meson64-edge.config:# CONFIG_RTL8822CS is not set linux-mvebu64-current.config:CONFIG_RTL8822CS=m linux-mvebu64-edge.config:CONFIG_RTL8822CS=m linux-mvebu-current.config:CONFIG_RTL8822CS=m linux-mvebu-edge.config:CONFIG_RTL8822CS=m linux-odroidxu4-edge.config:CONFIG_RTL8822CS=m linux-rk322x-current.config:CONFIG_RTL8822CS=m linux-rk322x-edge.config:CONFIG_RTL8822CS=m linux-rockchip64-current.config:CONFIG_RTL8822CS=m linux-rockchip64-edge.config:CONFIG_RTL8822CS=m linux-rockchip-current.config:CONFIG_RTL8822CS=m linux-rockchip-edge.config:# CONFIG_RTL8822CS is not set linux-rockchip-rk3588-legacy.config:# CONFIG_RTL8822CS is not set linux-sunxi64-current.config:CONFIG_RTL8822CS=m linux-sunxi64-edge.config:CONFIG_RTL8822CS=m linux-sunxi64-legacy.config:CONFIG_RTL8822CS=m linux-sunxi-current.config:CONFIG_RTL8822CS=m linux-sunxi-edge.config:CONFIG_RTL8822CS=m linux-sunxi-legacy.config:CONFIG_RTL8822CS=m linux-uefi-arm64-current.config:CONFIG_RTL8822CS=m linux-uefi-arm64-edge.config:# CONFIG_RTL8822CS is not set linux-uefi-riscv64-current.config:# CONFIG_RTL8822CS is not set linux-uefi-riscv64-edge.config:# CONFIG_RTL8822CS is not set linux-uefi-x86-current.config:CONFIG_RTL8822CS=m linux-uefi-x86-edge.config:CONFIG_RTL8822CS=m
This commit enables this for just the meson64-edge kernel as that resolves the issue I was researching, but I suspect it probably should also be enabled for rockchip-edge as well, but I don't have any such devices.
On branch rtl8822cs_meson64_edge Changes to be committed: modified: ../kernel/linux-meson64-edge.config
Description
How Has This Been Tested?
  • [x] Successfully built meson64-edge kernel and installed on a box
View the full article
