i use my BananaPI M2 Plus as a home router.
i have eth0, eth0.10 (vlan 10), eth0.1111 (vlan 1111)
on eth0 i have External IP from ISP by DHCP (original MAC ADDRESS)
on eth0.10 i have internal IP (192.168.10.1) (different - generated MAC ADDRESS)
on eth0.1111 have external IP from ISP for settopboxes. (cloned MAC ADDRESS from settopbox)
my issue is that 192.168.10.1 is unreachable after reboot. Have no idea why.
i discover that if i switch eth0.10 to promiscuous mode (tcpdump -c 10 -i eth0.10) after reboot it works.
any idea to make it less dirty?
thank you.
Hi @destinqo,
You didn't say which OS you are using, since your here on this forum, i'll assume its either debian or ubuntu?
Did you define your interfaces in /etc/network/interfaces? if so, under the section
iface eth0.10
try adding a line
    post-up tcpdump -c 10 -i eth0.10
Hope that works for you.
Dave.
i have debian, this tcpdump command i have at rc.local, but your solution is better.
What is interesting me is why i must do that?
thank you.
