Squatter Posted January 4, 2023 Share Posted January 4, 2023 My Opi3 has been running armbian for over 2 years (edge kernels & usually fully up-to-date). I have been using eMMC & I noticed an apparent slowdown about 6 months ago. As it performs cron-based tasks and is a stats collector, this performance was not noticable but doing a manual BIG dist-upgrade, it seems to take forever (20 minutes to do what should be under 5 minutes). If I run "mmc extcsd read /dev/mmcblk1", the results tell me that the eMMC is at least 90% used whatever that really means. Is this a sign of imminent failure ? hdparm shows read results of 17 MB/s which is actually slower than my alternative SD card boot device and nearly 1/10th the result of a mounted flash disk (146 MB/s). Am I right in assuming that the eMMC is really at the end of its life and I should look to move to an alternative primary storage for boot etc. I do all of my "work" on a mounted flash drive so data loss is not an issue. Is the way to go as follows : minimal boot from the eMMC or an SD card which switches ALL further OS work to the flash drive How does one formally disable the eMMC storage entirely ? Thanks 0 Quote Link to comment Share on other sites More sharing options...
Squatter Posted January 9, 2023 Author Share Posted January 9, 2023 I built Armbian fresh using sid this time as I have had zero problems with "Bookworm testing". The new SD build still shows a severely performance-affected eMMC so I am pretending it doesn't exist anymore. When a new fast flash drive arrives, I will use nand-sata-install with that. I did note that with a bootable SD and a bootable eMMC, while nand-sata-install did copy stuff over, it would boot from the SD but mount the eMMC /boot directory. Kernel upgrades would upgrade the eMMC mounted root but a reboot used the SD card version. I will look to see if a manual change to the mounted root fixes that. For the record, apart from the 1st 6 months in 2019 trying to use the vendor-supplied Linux (it was seriously flawed), I have been running Armbian successfully ever since. Any errors being of my own making. Thank you to the developers. 0 Quote Link to comment Share on other sites More sharing options...
