RSS Bot Posted January 6, 2023 Posted January 6, 2023 Description Most of Realtek drivers have a bug: P2P IE not passed to AP beacon. This causes problems, when P2P-GO looks like a regular AP. All P2P capable devices can't see my P2P-GO in the list. I found a driver where P2P-GO works fine (according to user reviews): https://github.com/aircrack-ng/rtl8812au And found these differences. After I backported these changes my P2P-GO works fine. Also this changes is totally safe, because affects only P2P-related code This patch contains my patches to the original driver repo: jwrdegoede/rtl8189ES_linux#87 jwrdegoede/rtl8189ES_linux#88 But the owner is too busy to review that :( How Has This Been Tested? Create /etc/wpa_supplicant/wpa_supplicant-wlan0.conf ctrl_interface=/var/run/wpa_supplicant update_config=1 device_name=orangepilite device_type=1-0050F204-1 config_methods=virtual_push_button p2p_no_group_iface=1 Setup DHCP for the wlan0: /etc/systemd/network/wlan0.network [Match] Name=wlan0 [Network] Address=10.7.7.7/24 DHCPServer=true IPMasquerade=ipv4 [DHCPServer] PoolOffset=100 PoolSize=20 EmitDNS=yes DNS=1.1.1.1 Setup services # We don't need NM sudo systemctl disable NetworkManager sudo systemctl stop NetworkManager # For test we need systemd-networkd sudo systemctl enable systemd-networkd sudo systemctl start systemd-networkd # Useless without NM sudo systemctl stop wpa_supplicant sudo systemctl disable wpa_supplicant # Enable wpa_supplicant for wlan0 sudo systemctl enable wpa_supplicant@wlan0 sudo systemctl start wpa_supplicant@wlan0 Now create P2P-GO: sudo wpa_cli p2p_group_add Open on android "Wifi Direct" section in settings. Now you can see "orangepilite" device in the list. Just click it! Accept join req from your phone to P2P-GO sudo wpa_cli wps_pbc In wpa_supplicant logs you can see something like that: <3>P2P-DEVICE-FOUND xx:xx:xx:xx:xx:xx p2p_dev_addr=xx:xx:xx:xx:xx:xx pri_dev_type=10-0050F204-5 name='Android_6d7f' config_methods=0x188 dev_capab=0x25 group_capab=0x0 new=1 <3>P2P-PROV-DISC-PBC-REQ xx:xx:xx:xx:xx:xx p2p_dev_addr=xx:xx:xx:xx:xx:xx pri_dev_type=10-0050F204-5 name='Android_6d7f' config_methods=0x188 dev_capab=0x25 group_capab=0x0 <3>WPS-PBC-ACTIVE <3>P2P-PROV-DISC-PBC-REQ xx:xx:xx:xx:xx:xx p2p_dev_addr=xx:xx:xx:xx:xx:xx pri_dev_type=10-0050F204-5 name='Android_6d7f' config_methods=0x188 dev_capab=0x25 group_capab=0x0 <3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 <3>CTRL-EVENT-EAP-STARTED xx:xx:xx:xx:xx:xx <3>CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=1 <3>CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=254 <3>WPS-REG-SUCCESS xx:xx:xx:xx:xx:xx xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx <3>WPS-PBC-DISABLE <3>WPS-SUCCESS <3>CTRL-EVENT-EAP-FAILURE xx:xx:xx:xx:xx:xx <3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 <3>AP-STA-CONNECTED xx:xx:xx:xx:xx:xx p2p_dev_addr=xx:xx:xx:xx:xx:xx <3>EAPOL-4WAY-HS-COMPLETED xx:xx:xx:xx:xx:xx That's successful connection. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
