[Armbian build PR] - RTL8189FS: Fix and enable secondary iface (wlan1)
Description
All RTL drivers have interesting working mode: -DCONFIG_CONCURRENT_MODE With this mode we have two or three interfaces: wlan0, wlan1 and wlan2 This useful, when we need both STA and AP/P2P-GO on one wifi card.
But wlan1 is not working in the 8189FS driver. We can create AP/P2P-GO on wlan1, and it is shown on any STA, but can't receive any RX packets. At the same time, wlan2 always works fine! That is mysterious! But after a few investigations, I found the reason: wlan0 and wlan1 have the same MAC! :)
For example:
wlan0 xx:xx:xx:xx:a5:8d
wlan1 xx:xx:xx:xx:a5:8d
wlan2 xx:xx:xx:xx:a1:8d
Originally, MAC changes only for if2 and later interfaces. This looks like a bug.
if (padapter->iface_id > IFACE_ID1)
    mac[4] ^= BIT(padapter->iface_id);
After fix wlan1 now works fine and have different mac:
wlan1 xx:xx:xx:xx:a7:8d
// Although we have the possibility to have two secondary interfaces, I did enable only one. I think that is more safe and basically enough. // Also, in armbian already present RTL drivers with enabled secondary iface. For example, tinkerboard with RTL8723BS.
This patch contains my patches to the original driver repo:
  • jwrdegoede/rtl8189ES_linux/pull/89
  • jwrdegoede/rtl8189ES_linux/pull/90
How Has This Been Tested?
I tested this with STA + P2P-GO (works similar to AP).
I have both connected to my WiFi router on wlan0 And P2P-GO group with connected phone to it.
  • [x] ping from router to OPi works fine (over wlan0)
  • [x] ping from phone to OPi works fine (over wlan1)
Any can test this:
  1. Create /etc/wpa_supplicant/wpa_supplicant-wlan0.conf for STA
network={
ssid="your_wifi_access_point"
psk=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
scan_ssid=1
  1. Create /etc/wpa_supplicant/wpa_supplicant-wlan1.conf for P2P-GO
ctrl_interface=/var/run/wpa_supplicant
update_config=1
device_name=orangepilite
device_type=1-0050F204-1
config_methods=virtual_push_button
p2p_no_group_iface=1
  1. Setup DHCP client for the wlan0: /etc/systemd/network/wlan0.network
[Match]
Name=wlan0
[Network]
DHCP=ipv4
[DHCPv4]
RouteMetric=10
[Link]
RequiredForOnline=false
#[Route]
#Gateway=192.168.1.1
#Destination=0.0.0.0/0
  1. Setup DHCP server for the wlan1: /etc/systemd/network/wlan1.network
[Match]
Name=wlan1
[Network]
Address=10.7.7.7/24
DHCPServer=true
IPMasquerade=ipv4
[DHCPServer]
PoolOffset=100
PoolSize=20
EmitDNS=yes
DNS=1.1.1.1
  1. Setup services
# We don't need NM
sudo systemctl disable NetworkManager
sudo systemctl stop NetworkManager
# For test we need systemd-networkd
sudo systemctl enable systemd-networkd
sudo systemctl start systemd-networkd
# Useless without NM
sudo systemctl stop wpa_supplicant
sudo systemctl disable wpa_supplicant
# Enable wpa_supplicant for wlan0 (STA)
sudo systemctl enable wpa_supplicant@wlan0
sudo systemctl start wpa_supplicant@wlan0
# Enable wpa_supplicant for wlan1 (P2P-GO)
sudo systemctl enable wpa_supplicant@wlan1
sudo systemctl start wpa_supplicant@wlan1
  1. Now create P2P-GO:
sudo wpa_cli -i wlan1 p2p_group_add
  1. Open on android "Wifi Direct" section in settings. Now you can see "orangepilite" device in the list. Just click it!
  2. Accept join req from your phone to P2P-GO
sudo wpa_cli -i wlan1 wps_pbc
In wpa_supplicant logs you can see something like that:
<3>P2P-DEVICE-FOUND xx:xx:xx:xx:xx:xx p2p_dev_addr=xx:xx:xx:xx:xx:xx pri_dev_type=10-0050F204-5 name='Android_6d7f' config_methods=0x188 dev_capab=0x25 group_capab=0x0 new=1
<3>P2P-PROV-DISC-PBC-REQ xx:xx:xx:xx:xx:xx p2p_dev_addr=xx:xx:xx:xx:xx:xx pri_dev_type=10-0050F204-5 name='Android_6d7f' config_methods=0x188 dev_capab=0x25 group_capab=0x0
<3>WPS-PBC-ACTIVE
<3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
<3>CTRL-EVENT-EAP-STARTED xx:xx:xx:xx:xx:xx
<3>CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=1
<3>CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=254
<3>WPS-REG-SUCCESS xx:xx:xx:xx:xx:xx xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
<3>WPS-PBC-DISABLE
<3>WPS-SUCCESS
<3>CTRL-EVENT-EAP-FAILURE xx:xx:xx:xx:xx:xx
<3>AP-STA-CONNECTED xx:xx:xx:xx:xx:xx p2p_dev_addr=xx:xx:xx:xx:xx:xx
<3>EAPOL-4WAY-HS-COMPLETED xx:xx:xx:xx:xx:xx
That's a successful connection.
Now you can verify ping from phone to orangepilite (over WiFi Direct) and from router to orangepilite (over regular WiFi).
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [ ] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
