[CNX-Software] - ROCK Base triple-frequency RTK/GNSS base station works with Web3 GEODNET decentralized network
ROCK Base RTK network base station
ROCK Robotic has announced the ROCK Base triple-band multi-constellation RTK/GNSS base station that works with the Web3 GEODNET decentralized GNSS reference network, with the solution designed to offer centimeter accuracy to support applications such as civil surveying, high-definition mapping, digital twin creation, and robotic solutions. Real-time Kinematic (RTK) is a relative positioning technique relying on GNSS (GPS,  Galileo, GLONASS, Beidou …) and allowing centimeter positioning accuracy. The technique requires an RTK “Base station” like the ROCK Base and a lower-cost “Rover station” typically attached to a vehicle or drone. For higher accuracy, it’s also possible to use a Network RTK: Network RTK is based on the use of several widely spaced permanent stations. Data from reference stations is combined in a common data processing in a control center. The control center computes corrections for the spatially correlated errors within the network. These corrections are transmitted to the rover. Comparing to [...]
The post ROCK Base triple-frequency RTK/GNSS base station works with Web3 GEODNET decentralized network appeared first on CNX Software - Embedded Systems News.
View the full article
