Hi
I want to modify base armbian image using choot in order to install necessary software. I am also creating user during that process.
My question is how can I skip or prefill the form that appears on first run? (user creation, time zone setting etc.)
I was surfing the forum and found this answer.
So, I came up with few options:
1) It looks like I can prefill my desired values for the form in "/usr/lib/armbian/armbian_firstlogin" file by editing it during chroot
2) I can remove user input parts in "/usr/lib/armbian/armbian_firstlogin", but preserve other important lines, since user will be created during chroot
Is this valid options or there is more proper way to do this?
Edited by Roman Khudobei
  • Roman Khudobei changed the title to Prefill form fields on first run
I don't know if editing armbian_firstlogin is the right thing to do. Wouldn't it prevent the source code from being updated (git pull) or make it more difficult? Did you already looked at the following links?
Don't have experience with such things yet, but hope it helps.
Thank you @atone for sending links, I will check them. Looks like it's related to custom Armbian build creation. I don't want to dig into it right now, because I'm not familiar with those processes and it will take some time to learn.
Looks like editing armbian_firstlogin works for me currently.
