Badger Posted January 17, 2023 Posted January 17, 2023 Logs: https://paste.armbian.com/kasujazuwo Hi, I've been looking to run the desktop version of Armbian on the M5 however it will not start (blank screen, no signal). I can see the Debian Icon at startup, and the Armbian Icon at shutdown. startx does not bring it up, however sudo startx will but I'm not sure if this is the best way. I have tested: Armbian_22.11.3_Bananapim5_bullseye_current_6.1.4_gnome_desktop.img Armbian_22.11.3_Bananapim5_bullseye_current_6.1.4_cinnamon_desktop.img and both are the same. Any ideas are appreciated! Thanks. 0 Quote
SoSie Posted January 25, 2023 Posted January 25, 2023 It seems to be a alsa issue according to this post https://forum.odroid.com/viewtopic.php?t=41546 I am still on the previous armbian on my side using archive having booting or screen issues : https://imola.armbian.com/archive/bananapim5/archive/ 0 Quote
Badger Posted January 28, 2023 Author Posted January 28, 2023 Hi SoSie, Thanks for your message, that is what I did in the end - I went back to: Armbian_22.08.7_Bananapim5_bullseye_edge_5.19.16_gnome_desktop.img and is booting into the desktop now, but I'm sure I still had those errors in dmesg 🤔 I thought it was due to a permissions problem, but didn't know where to look.. 0 Quote
Badger Posted March 1, 2023 Author Posted March 1, 2023 Hi, I have just tested Armbian_23.02.2_Bananapim5_bullseye_current_6.1.11_gnome_desktop and it also has the same problem. Thanks.. 0 Quote
R. Posted October 21, 2023 Posted October 21, 2023 (edited) I have no problem with any of the Bananapi images, but can’t get any of the Armbian one booting. Armbian_22.08.7_Bananapim5_bullseye_edge_5.19.16_gnome_desktop.img Also gives me a black screen. I am also having trouble with images as well. (Gnome desktops) 6x and all 5x kernels. I’ll connect via serial soon. To see what’s going on. My blue and red lights are solid (not flashing but on ) lcd gets an HDMI signal but black screen. I’ve switched cables and tried multiple screens. Armbian usually always boots well for me. I find it hard to believe any of the images are bootable of an SD, am I missing something here ? Edited October 21, 2023 by R. 0 Quote
c0rnelius Posted October 21, 2023 Posted October 21, 2023 This should correct the audio issue. Run as root `sudo su` and only choose one. # ANALOG amixer -c 0 set 'TOACODEC OUT EN' 'on' amixer -c 0 set 'TOACODEC SRC' 'I2S B' amixer -c 0 set 'TDMOUT_B SRC SEL' 'IN 0' amixer -c 0 set 'FRDDR_A SRC 2 EN' 'on' amixer -c 0 set 'FRDDR_A SINK 1 SEL' 'OUT 0' amixer -c 0 set 'FRDDR_A SINK 2 SEL' 'OUT 1' amixer -c 0 set 'FRDDR_A SINK 3 SEL' 'OUT 2' amixer -c 0 set 'ACODEC' '85%' alsactl store # HDMI amixer -c 0 set 'TOHDMITX' 'on' amixer -c 0 set 'TOHDMITX I2S SRC' 'I2S B' amixer -c 0 set 'TDMOUT_B SRC SEL' 'IN 0' amixer -c 0 set 'FRDDR_A SRC 2 EN' 'on' amixer -c 0 set 'FRDDR_A SINK 1 SEL' 'OUT 0' amixer -c 0 set 'FRDDR_A SINK 2 SEL' 'OUT 1' amixer -c 0 set 'FRDDR_A SINK 3 SEL' 'OUT 2' amixer -c 0 set 'ACODEC' '85%' alsactl store 0 Quote
