RSS Bot Posted January 26, 2023 Posted January 26, 2023 Description Fixes meson64 current & edge kernels. Add patch https://patchwork.kernel.org/project/linux-amlogic/patch/d9721029-780e-09f1-0207-72d3897032a4@gmail.com/ The usage of edge-triggered interrupts lead to lost interrupts under load, see [0]. This was confirmed to be fixed by using level-triggered interrupts. The report was about SDIO. However, as the host controller is the same for SD and MMC, apply the change to all mmc controller instances. [0] https://www.spinics.net/lists/linux-mmc/msg73991.html Fixes: 1499218c80c9 ("arm64: dts: move common G12A & G12B modes to meson-g12-common.dtsi") Reported-by: Peter Suti <peter.suti@streamunlimited.com> Tested-by: Peter Suti <peter.suti@streamunlimited.com> Jira reference number AR-1522 How Has This Been Tested? [X] JetHub D1 Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [ ] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
